Coolant reservoir
Reldn
Missouri
'25 Wrangler Willys 2dr, '22 Blazer, '22 Ram 1500
Looks good. Where did you get it from? If you don't mind me asking.
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
Tim_JLU
Tim_JLU
Tim
2019 JLU Sahara
Tim_JLU
Tim_JLU
Tim
2019 JLU Sahara
I have not installed yet.
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
Am I wrong, or can you not see the fluid level in it? Does have a sight glass or something? I'd hate not being able to see the level without taking the cap off.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Am I wrong, or can you not see the fluid level in it? I'd hate not being able to see the level without taking the cap off.
Looks like cap removal is required to check the coolant level. That'd be the same as what the OEM opaque black polymer coolant tank requires.
I agree that the absence of a sight glass is a missed opportunity.
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
I paid 218.00
You got a link for yours?
I’m curious on the aliexpress one too though but I’ll let it simmer on the aftermarket first before purchasing.
GladiatorPilot23
So Cal
2023 Gladiator Rubicon Eco-Diesel
Man i got curious and googled away, found one on ali express. Looks just like the plastic ones but aluminum.
https://www.aliexpress.us/item/3256807257613490.html?gatewayAdapt=glo2usa4itemAdapt
for $300 not sure I want to take the risk yet but it looks like it has everything we need.
I was about to buy one and then found this thread when I was doing some google searching on it. I took time to look it over and it's a high quality CNC pieces. This would be the last reservoir you would buy. He even incorporated the OEM baffles.
" The baffles in your coolant reservoir are there to help control the flow of the coolant and reduce splashing. When the coolant expands and contracts due to temperature changes, the baffles help prevent the liquid from sloshing around too much. This helps to maintain consistent coolant levels and can also reduce the chances of air being introduced into the system, which could cause issues like overheating or erratic coolant flow. Essentially, they keep things stable and more efficient, especially in systems that have a high rate of flow or fluctuate a lot in temperature. "
This was was $$$ and time to make. Very impressive for CHINA. The fins will help remove heat. The top hose connection nipple is CNC and not 2 pieces and this will not happen.
Also other issues like cracking at the seams will not happen. The black OEM reservoirs, which is supposed to be a stronger plastic still did not hold up at the center bond. Even connects to the factor bottom hose! 2 Negatives are $$$ but more reliability and quality and and not clear to see the coolant level.
This was the least expensive link. https://www.aliexpress.us/item/3256...NzQwMjI1MDExLjIzLjAuMA..&gatewayAdapt=glo2usa
The seller did a $25 off auto coupon then Ali had a $30 off coupon on the one of there promos they Run. I'll post back after the install. Let see.
Jeep Wrangler JL Coolant reservoir 1740224039994-j5
Jeep Wrangler JL Coolant reservoir 1740224152019-jb
Jeep Wrangler JL Coolant reservoir 1740223510665-u5
Jeep Wrangler JL Coolant reservoir 1740224386266-3g
