richk225
- Rich
- Jan 16, 2018
- New Jersey
- 2021 392Rubicon XR 2017 Jeep Grand Cherokee
- Occupation
- retired due to broken back
Plus the right rear tire and rim are also pointing in a different direction.Longer LCAs will probably help, but I'm not sure if you'd want adjustable arms to make sure the front pinion angle is OK. I don't know how much lift acceptable before you run into those problems. The drop brackets could be a good fix too.
Also, is this your actual Jeep? I see damage to the rear door and the roof looks tweaked, so my guess is something is off in the rear suspension as well, unless it's been repaired since the pic was taken.
