Best steering stabilizers so far?
Bobjon18
Jon
Waco
2018 Jeep Wrangler Rubicon
In the last month I have decided to joint the Jeep family! Purchased a 2018 wrangler unlimited rubicon JL. My fiancé drives it primarily so this will more than likely be a mall crawler unless there is some way I can get it off road without her knowing. With that said I have read several posts about steering feeling a touch wobbly or loose and keep reading the fix is a better steering stabilizer. I have seen several good reviews for different brands so my question is which does the forum like the most?
Bobjon18
Jon
Waco
Thanks pled I’ve been seeing that one come up on posts. Do you have one?
plex
Cincinnati, OH
Weekend keyboard mechanic and beer drinker
Yes, I do. One of the best investments I did to my JL. There are several forum vendors will sell it for discount.
Kansas JL
Kansas
2018 Rubicon ( sold). 2022 392 XR Tuscadero
I agree. I changed out my stock one a few weeks ago for the Falcon 2.2. It helped with the wandering ( not a cure for it). It just makes it less pronounced. But defiantly a imporovment worth doing.
Edorand
NY
I have Fox 2.0 and it'd been great for the last 1500+ miles
PEABUDY
2019 JLUR GRANITE CRYSTAL
I did the falcon nexus 2.1 and like it. Did not see myself crawling underneath JL to change settings on the 2.2.
JLJoy
Wichita
2021 Rubicon JLU 3.0 Diesel
I have the Fox 2.0 also. Had it for almost 2k miles and it has made a huge difference.
Bobjon18
Jon
Waco
Is the fox adjustable? Is the adjustability even necessary if I won’t be doing any aggressive trailing? I may do some lite or moderate off-roading but nothing major.
Tpham
Tom
ohio
2018 jeep wrangler sport s
Says it has 24 clicks of adjustment.
jruss
Josh
Greater Baton Rouge Area
2018 Jl Sport Unlimited
Good drag link + good tie rod + good caster = throw your “stabilizer” in the trash and actually impress your friends.
MojitoJLUR
Detroit, MI
2018 JLUR Mojito
Does a steering stabilizer fix the steering wheel shake when you hit a bump on the road?
Carlton
Chicago
Jeeps lots of jeeps
It helps mask it/reduce it. Proper geometry and strong parts cure it. The real fix would be upgraded tie rod, drag link (flip kit if lifted), and track bar.
