Great Pumpkin
Michael
Albuquerque, NM
2018 Jeep Wrangler JLU Sport S 6 Speed, 2023 Wrangler JLU Sport S Automatic
Aviation Maintenance
So, after reading about what others have built for platforms and sweating over my rusty woodworking skills, I finally bit the bullet and designed my own to be super simple and easy to install/remove. It was all done from one sheet of 3/4” maple plywood that cost $89 at Lowe’s. I made a template out of cardboard and made a few adjustments once I traced it onto the plywood. Below is the finished platform with the carpet I chose because it was $14 at Lowe’s.
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5330
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5328
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5331
Great Pumpkin
Great Pumpkin
Michael
Albuquerque, NM
The hardest part was figuring out how to support the front. I used scrap from the same sheet of plywood at a height of 9”. Then attached everything using pocket hole screws. I also used a strip across the underside to fill in a gap and make it more firm.
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5325
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5326
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5327
Great Pumpkin
Great Pumpkin
Michael
Albuquerque, NM
I opted to leave in the 40% seat and keep access to the rear cup holders.
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5332
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5333
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5337
Great Pumpkin
Great Pumpkin
Michael
Albuquerque, NM
It’s not attached to anything, the weight holds it in place and access to the rear storage is easy by just lifting the rear of the platform. The platform doesn’t shift, squeak or rattle; nice and quiet. The real beauty of this design is I did not have to pull out anything but the 60% seat. The carpet and rear floor mat stay where they are. I can pull this out and reinstall the rear seat at anytime. The notch on the rear drivers side is to accommodate a bottle opener I mounted next to my tailgate table.
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5335
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5321
Great Pumpkin
Great Pumpkin
Michael
Albuquerque, NM
These are some pictures I took that show some measurements. And one final one just because. ?
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5322
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5320
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5319
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5318
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5317
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5316
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5315
Jeep Wrangler JL Simple, practical (Goose-Gear-like) platform. IMG_5276
Great Pumpkin
Great Pumpkin
Michael
Albuquerque, NM
I still need both my seats but when the kids are gone in a couple years I would love to do something like that. Well done!
Thanks for the love! Yeah, my daughter is grown up so I can do pretty much what I want with the back of the Jeep. I still can’t justify the full cost of a Goose Gear platform, although I’d love to have that set-up. My full cost for materials came in around $150, so I’m tickled it turned out as well as it did. ?
Flip
Johnny
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Nice job! You could put a 3" piece of foam (cut to fit) in there and get a very good night's sleep.
roaniecowpony
Retired Engineer
Great job. I currently have the full width version of your platform. That is, it removes both rear seat sections and provides a platform for the hunting dogs.
I was thinking of making it so I could have one rear seat exactly like you did. IIRC, there's an issue with supporting the 40% seat, at least with my 2018. Can you explain what you had to do to support the seat?
Mudduck
Jay
Michigan
2021 Willys 4door
Wouldn’t the 60% seat delete bracket work? Or was there still an issue using that? I’ve received mine, but haven’t had time to install it yet.
roaniecowpony
Retired Engineer
Sorry, I guess I don't know what a 60% delete bracket is.
