mchastings
I am not an electrician, so I can only hypothesis, My wife has a 2015 Rubicon, still factory in terms of mods. Car wouldn't start the other day, I checked battery, Good, fuses, Good, starter, Good, saw a utube video on grounding straps, pulled up a schematic and found every grounding strap/cable and tightened them. Every ground was good with only a couple needing a slight turn, nothing that would cause concern. The damn thing started and has been trouble free for the last 27 days. I had checked for grounding with a multi meter when I started and did show voltage fluctuations (minor) that indicated a ground issue so fingers crossed. So maybe! Getting back to Diesels, my 2020 JL died on me when I was driving last year and it turned out to be the batteries. My electrical system went haywire when it died with lights blinking, wipers moving, dome light and then nothing, not even enough power for the emergency blinkers. (turns it it blew a main fuse) So, my question, since the Aux battery is smaller, doesn't it make since that it will use up its electrons before the bigger one, and when its dying it becomes a parasite to the main battery, and since they are wired in parallel, you really wont be able to tell with a multi meter until the main starts to lose its ability to recharge?Replaced the aux without replacing the main? They're like Romeo and Juliet: they die together.
