rickinAZ
Two months ago, I switched from 35” Mickey Thompson Baja MTZs to 37” BFG KO2s. The decision was helped by the fact that the unsprung weight was nearly identical—65 lbs versus 66 lbs.
I wasn’t concerned about gearing because the vehicle is driven exclusively on-road, and with a close-ratio eight-speed transmission, the only potential downside would be initial takeoff in first gear. With 442 lb-ft of torque available at 1,400 rpm, that proved to be essentially imperceptible.
I’m a creature of habit and my driving patterns are very consistent, which made it easy to evaluate the impact on fuel economy. Surprisingly, mileage has increased by roughly 10–15%.
