BulletProof Supplemental Cooling System 2021-2023 Jeep Gladiator/Wrangler Diesel
Prime
Sean
Thousand Oaks
2021 Jeep Gladiator Overland
Buttoning up the prototype install…
Also installing the larger Mishimoto radiator and 2024 grill to catch as much air as possible.
I’ll be towing a 6000lb trailer and full bed of cargo up grapevine on I-5 this weekend…
Have no idea how this will play out, but I’ve just about done everything in my power to solve the derate problem.
Jeep Wrangler JL BulletProof Supplemental Cooling System 2021-2023 Jeep Gladiator/Wrangler Diesel IMG_7619
AZ-Chris
Arizona
2020 JL Unlimited Rubicon Diesel
Looks good . . . Is Bullet Proof Diesel onboard with this mounting system? Do you think this would work with the OEM steel bumper with winch?
Prime
Sean
Thousand Oaks
I designed it to fit with the oem steel bumper, electronic sway bar disconnect and winch, but I haven’t done a fitting on a vehicle with those features yet.
BPD is aware that the plate was being prototyped but I haven’t heard anything from them recently so the ball is kinda in their court at this point.
I have one more sample on hand that is currently being powder coated — my intention we to send this unit to BPD, but may just sell it to someone else if they aren’t interested.
ChuckQue
ChuckQue
Chuck
2022 JLURD
Jeep Wrangler JL BulletProof Supplemental Cooling System 2021-2023 Jeep Gladiator/Wrangler Diesel IMG_7604
This looks amazing. I can’t wait to see the results, and I’ll gladly throw money at this if it works…0
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Love this ! Bravo !🙌
driventoadventure
Lrr
Northern Front-Range, Colorado
21 JLURD
Employed Gainfully
Good Luck and I am really excited to hear if it helps or not. I was just towing 3800lbs to Montana this weekend through some "snow", while coolant was at 208, oil would still hit 250 before I had to let off the throttle during the few "climbs".
1BadDad
Zach
Tulsa, OK
2021 JLURD
IT Innovator
Whoa developments looking good! Cant wait to hear results!
9mmkungfu
United States
2020 JLURD
Any idea if it will work with all of the above + Maximus-3 tow loops?
Prime
Sean
Thousand Oaks
It should be a good fit with the above criteria.
The tow loops you reference are outboard of the plate mounting pylons, so highly unlikely that you would have any interference with this configuration.
Prime
Sean
Thousand Oaks
rickinAZ
Phoenix
I am experiencing overheating issues. I have a 2021. I live in IL, flat country. I overheat bad at highway speeds 65 mph+ in 70+ degree weather. It drives me absolutely livid. I have the EVO 1/4 stubby which is low profile and does not restrict airflow. I am looking into getting a new aftermarket radiator as everything regarding the coolant system is fine and has been checked over and topped off and tested multiple times. So the radiator is clogged and I have washed it through the fan and from the front and nothing helps so if I am going to go through the trouble of taking it out- I am just going to replace it woth something better. Do you know if this aux cooler would add airflow efficiency with an aftermarket radiator? Or should I just do the radiator? Im willing to spend a pretty penny here as this issue is driving me absolutely mental and I just want it fixed.
Mine didn't come close to overheating during the hottest July ever in Phoenix (119° peak with every single day in the 110s). And...that's with the stock radiator. You have something wrong.
Tpsillos
Trey
South Carolina
2021 JLUD
Welding Inspector
great idea, I just feel like where its mounted it would get taken out pretty quick by a rock, my bumper and skid is pretty banged up.
ChuckQue
ChuckQue
Chuck
2022 JLURD
Damn that came out nice. I agree that if you do serious rock crawling it’s still low hanging fruit, albeit better protected than it was. That being said with how many people don’t rock crawl their jeeps, I believe there is a solid market for this especially for the JT users since they likely tow or even just have heavy overland builds and need more cooling capacity.
Really nice work you did. I wish BPD was being more cooperative with you.
Prime
Sean
Thousand Oaks
The guys at BPD are just super busy. Actually was such a compliment that they sent me a beta unit for testing.
The cooler skid plate is attached to the frame pylons with 2 forward facing bolts — so the cooler is easily removable in about 5 minutes if rock crawling is on the agenda (you’d just need to complete the cooling loop with a barb fitting). So in that sense, the whole assembly can be rapidly deployed when your driving circumstances require additional cooling capacity.
